dynamic layers and DescribeCoverage requests
Ara T Howard
ara.t.howard at NOAA.GOV
Tue Dec 26 10:16:03 EST 2006
On Sat, 16 Dec 2006, Ara.T.Howard wrote:
> hi all-
> few newb questions:
> 1) i'm adding a dynamic layer via mapscript/php using this code:
> $oMap = ms_newMapobj("/data/ut_night_mosaics.map");
> $oLayer = ms_newLayerObj ($oMap);
> $oLayer->set('name', 'foo');
> $oLayer->setProcessing ("SCALE_1=0,63");
> $oLayer->setMetaData ("wcs_description" , "F152003 11 28 mosaic");
> $oLayer->setMetaData ("wcs_name" , "mosaic");
> $oLayer->setMetaData ("wcs_label" , "vis_mosaic");
> $oLayer->setMetaData ("ows_srs" , "EPSG:4326");
> $oLayer->setMetaData ("ows_extent" , "-180 -75 180 75");
> $oLayer->setMetaData ("wcs_resolution" , "0.00833333 -0.00833333");
> $oLayer->setMetaData ("wcs_bandcount" , "1");
> $oLayer->setMetaData ("wcs_formats" , "GEOTIFF");
> $oLayer->setMetaData ("wcs_nativeformat" , "8-bit GeoTIF");
> $oLayer->setMetaData ("wcs_rangeset_name" , "vis_mosaic");
> $oLayer->setMetaData ("wcs_rangeset_label" , "vis");
> $oLayer->setMetaData ("wcs_rangeset_axes" , "bands");
> $oLayer->setMetaData ("wcs_bands_name" , "bands");
> $oLayer->setMetaData ("wcs_bands_semantic" , "http://www.ngdc.noaa.gov/dmsp/");
> $oLayer->setMetaData ("wcs_bands_refSys" , "European Petroleum Survey > Group (EPSG)");
> $oLayer->setMetaData ("wcs_bands_label" , "F152003");
> $oLayer->setMetaData ("wcs_bands_values" , "VIS");
> $oLayer->set('status', MS_OFF);
> $oLayer->set('dump', MS_TRUE);
> $oLayer->set('data', "F1520061123.nt.d.OIS.vis.mos");
> $oLayer->set('dump', MS_LAYER_RASTER);
> $oLayer->setProjection ("init=epsg:4326");
> $oMap->owsdispatch($request);
> $contenttype = ms_iostripstdoutbuffercontenttype();
> header("Content-Type: $contenttype");
> ms_iogetStdoutBufferBytes();
> ms_ioresethandlers();
> this works fine: i can make wcs requests for the 'foo' layer. however, a
> DescribeCoverage request does not seem to pick up on the dynamic layer via
> owsdispatch. what else should i look into doing?
sorry for replying to my own post, but does anyone have insight into whether
or not the creation of dynamic layers should result in additional components
from a DescribeCoverage request? is this a feature or a bug?
regards.
-a
if you find yourself slandering anybody, first imagine that your mouth is
filled with excrement. it will break you of the habit quickly enough. - the
dalai lama
