tile4ms question
Jerl Simpson
jerl.simpso at GMAIL.COM
Fri Feb 3 14:37:20 EST 2006
Just an update, I upgraded to mapserver 4.8.0 and tried using the tile4ms
provided, with the same result.
If anyone has any ideas I'd greatly appreciate any help you might be able to
give.
Thanks,
Jerl
On 2/3/06, Jerl Simpson <jerl.simpso at gmail.com> wrote:
> I'm not sure if this should be posted here or not, if not please point me
> to the right place.
> I'm having trouble with tile4ms opening the files from at least one of my
> Metafile.txt files.
> The command I run is as follows:
> tile4ms Metafile.txt tileindex
> error is:
> Aborted. Unable to open
> SHP:/var/mapping/tiger_2005/PriRoad/tiles/PriRoad_0037.200_-105.400
> I thought maybe my filename was too long, but I checked the source, 255 is
> the max. So I'm OK there.
> ogrinfo has this to say about the file:
> Layer name: PriRoad_0037.200_-105.400
> Geometry: Line String
> Feature Count: 459
> Extent: (-104.835908, 36.412144) - (-104.424129, 37.988177)
> Layer SRS WKT:
> GEOGCS["NAD83",
> DATUM["North_American_Datum_1983",
> SPHEROID["GRS 1980",6378137,298.257222101 ]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]]
> MODULE: String (8.0)
> CFCC: String (3.0)
> FENAME: String (30.0)
> FETYPE: String (4.0)
> I'm running mapserver version 4.6.0, should I upgrade to 4.8.0?
> The shape is a small file, 50K, so I can provide it if need be.
> thanks
> Jerl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060203/7affa767/attachment.html
