tile4ms question
Jerl Simpson
jerl.simpso at GMAIL.COM
Fri Feb 3 10:05:28 EST 2006
I'm not sure if this should be posted here or not, if not please point me to
the right place.
I'm having trouble with tile4ms opening the files from at least one of my
Metafile.txt files.
The command I run is as follows:
tile4ms Metafile.txt tileindex
error is:
Aborted. Unable to open
SHP:/var/mapping/tiger_2005/PriRoad/tiles/PriRoad_0037.200_-105.400
I thought maybe my filename was too long, but I checked the source, 255 is
the max. So I'm OK there.
ogrinfo has this to say about the file:
Layer name: PriRoad_0037.200_-105.400
Geometry: Line String
Feature Count: 459
Extent: (-104.835908, 36.412144) - (-104.424129, 37.988177)
Layer SRS WKT:
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
MODULE: String (8.0)
CFCC: String (3.0)
FENAME: String (30.0)
FETYPE: String (4.0)
I'm running mapserver version 4.6.0, should I upgrade to 4.8.0?
The shape is a small file, 50K, so I can provide it if need be.
thanks
Jerl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060203/d7f69819/attachment.html
