help for projections
Janeks Kamerovskis
janeks.kamerovskis at SILVA.LV
Fri Feb 3 18:05:46 EST 2006
I want to be able show data in my (X, Y) maps in Lat Long.
I somehow can get it somewhere near - shifted ~ 200 km to W and ~100 to S.
I would appreciate some help - what could be wrong!
So I did folowing under MAP definition
PROJECTION
# "proj=tmerc" # by description it seems for me that I should use this one
"proj=utm" # by using this I can get lat long points somewhere near
# "ellps=WGS84"
"ellps=GRS80"
"lon_0=24E"
"k=0.999600"
"y_0=500000"
"units=m"
"north"
END
Then I have layers in X, Y i.e. without Projection definition
And then layer that data is lat long:
LAYER
NAME "test01"
TYPE POINT
STATUS ON
PROJECTION
"proj=latlong"
# "ellps=WGS84"
"ellps=GRS80"
# "datum=WGS84"
END
FEATURE
POINTS
# 503968.0 6307054.0
27.1 57.0 #this values shows point in
right place
24.24 56.09 #this is the point real (right)
coords
END
# TEXT "Test inline"
END
CLASS
NAME 'Test01'
SYMBOL 'triangle'
SIZE 14
COLOR 255 0 255
END
END
Ģeogrāfiskā koordinātu sistēma- GRS 1980.
Meridiāns- Grīnvičas
Datums- D_GRS_1980
Mērvienība- grādi
Projekcijas koordinātu sistēma- Transverse Mercator
FalseNorthing- 0
CentralMeridian- 24
OriginLatitude- 0
FalseEasting- 500000
ScaleFactor- 0.9996
brgrds
Janeks
