Visualizing Point Data
Bill Binko
bill at BINKO.NET
Sun Feb 5 12:16:10 EST 2006
On Fri, 2006-02-03 at 11:40 -0800, Dylan Beaudette wrote:
> I was just working on this last night:
> http://casoilresource.lawr.ucdavis.edu/drupal/node/172
> check out the source for v.kernel in GRASS
Dylan,
This is an excellent example of what I'm trying to achieve. Here are
some quick thoughts about what you've shown:
1) How would you publish this "live" to the web? Do you know how to
integrate v.kernel to push its output to mapserver directly? I know
there are tools to push GRASS output through GDAL, and I suspect that
that could be daisy chained into mapserver, but I'd like someone's
opinion who's actually done this. If there's an example (anybody?) or
HOWTO of how to leverage GRASS this way?
2) What is the performance of v.kernel. For example, I'll have 30-100K
points over the state of florida. For a zoomed out view, how long would
that take to draw? Perhaps a better question would be, what is the
order of complexity of the approach taken by GRASS.
3) Unfortunately, because I may want to integrate this into Mapserver, I
can't quite look at the GRASS source on this. More specifically, I
can't copy it since it's GPL into Mapserver, which is BSD and then
distribute it. Now: I may choose to simply write code to call GRASS
externally, but I wouldn't need to explore the source for that.
I will however, get GRASS 6 up and running here so that I can explore
it. Thanks for the pointer.
Bill
Bill Binko <bill at binko.net>
