Improve WMS Server Performance
Frank Warmerdam warmerdam at POBOX.COM
Sun Feb 5 16:03:39 PST 2006
On 2/5/06, Kyle Mulka <mulka at umich.edu> wrote:
> I think the information I need would fit in the documentation here under
> Preprocessing-rasters:
> http://mapserver.gis.umn.edu/docs/howto/raster_data/#preprocessing-rasters
Kyle,
The short answer is that you should convert the data to an
internally tiled format, and then build overviews.
eg.
gdal_translate -co TILED=YES your.tif tiled.tif
gdaladdo tiled.tif 2 4 8 16 32 64 128 256
> One program I've looked at is gdaladdo: How do I test to make sure
> overlays are in fact being used? How do I know what levels of overlays
> to create? How do I systematically test performance so that I know what
> I'm doing to the images is a good use of my, and my computers processing
> time?
To check if the overview generation worked, run the gdalinfo
program.  After each band listed it will show the overviews
present.   If GDAL sees them, then they should be used.
> I wonder if I could reduce the quality of the images slightly to improve
> performance.
There should be no need for this.
You should really provide details of your LAYER definition,
and the gdalinfo report from the data for better feedback.
Best regards,
More information about the MapServer-users mailing list
