Symbol sizing change in behaviourfrom 4.6 to 4.8
Merrett, Mike
mike.merrett at WHITEHORSE.CA
Wed Feb 8 12:17:46 EST 2006
I have upgraded to 4.8.1 (php) and still have the same issue (larger
images not being scaled down by parameters in map file)
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Monday, February 06, 2006 12:44 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU; Merrett, Mike
Subject: Re: [UMN_MAPSERVER-USERS] Symbol sizing change in behaviourfrom
4.6 to 4.8
Mike: I'll have to do some testing. Image scaling should still work. You
should try 4.8.1 though since there were a lot of symbol code changes in
the early betas that could be causing the problem.
Steve
>>> "Merrett, Mike" <mike.merrett at WHITEHORSE.CA> 02/06/06 12:30 PM >>>
Hi:
I use some gif files as symbols on a map ( e.g.. wildlife spotting at a
point shows a moose) --- since upgrading to 4.8beta1 (php map script)
shrinking of the images does not occur. Has this happened to anyone
else -- or am I using a broken feature which was fixed.
MAP FILE:
IMAGETYPE png
layer
debug off
name "Wildlife Sightings"
group "Wildlife Sightings"
connection "WILDLIFE\Wildlife
Sightings\Wildlife_Sightings_Working_Copy.TAB"
connectiontype OGR
metadata
description "Wildlife Sightings"
RESULT_FIELDS "Species Comments Date Time"
end
status off
type point
TOLERANCE 80
TOLERANCEUNITS meters
classitem Species
class
expression 'Moose'
name "Wildlife Sightings - moose"
template "x.html"
color 255 128 255
symbol 'moose'
size 15
end
end
SYMBOLS.SYM file:
symbol
name 'moose'
type pixmap
image 'moose.gif'
transparent 0
end
Mike Merrett
