Oracle-Connection-Pooling in Java
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Feb 13 04:25:02 EST 2006
Benedikt,
since I am looking this issue would'n t you mind opening a bug for the
inclusion of msConnPoolCloseUnreferenced in mapscript and one for the
memory leaks (add me to the cc list)?
Reagrds,
Umberto
On 1/2/06, Benedikt Rothe <umn-ms at hydrotec.de> wrote:
> Hi list members,
> From former threads I got the impression, that there are some folks
> interested in the Oracle/Mapserver/Java/Tomcat.
> Therfore I'd like to share experiences I made with using Connection-Pooling
> of
> Oracle-Connections inside Java/Tomcat.
> Testenvironment: Mapserver 4.6.2; Suse-Linux; Tomcat 4.1.31; Sun-Java 1.4.2
> Simulating 5 Browsers, which produce maps, query features, make selections,
> query-legend-pics frequently.
> - After using synchronized "enough" I didn't have crashes of Tomcat.
> - Big memory leak: Between the first 5 requests and the next 100 requests
> the Tomcat-process became about 400MB bigger. (I use "top" for
> watching memory-footprint.)
> - Cleaning the Connection-Pool "by hand". This means:
> Opening the function msConnPoolCloseUnreferenced in mappool.c
> for use in Java and call it after every request.
> - After this I still have memory leaks: About 100MB for 30.000 requests.
> (I also made a test: 25.000 requests without Connection pooling. Memory
> increased
> and decreased as expected in this case.)
> - Performancecomparison in my testcase:
> Without use of connection-pooling: ~ 50 Request per minute
> With use of connection-pooling: ~75 Request per minute
> As a result I have the following encouragements:
> - Making msConnPoolCloseUnreferenced availabe for mapscript via swig.
> (I made a hack by directly editing mapscript/java/mapscript_wrap.c and
> Java-Files in mapscript/java/edu/umn/gis/mapscript.) I
> think this
> function could be part of the mapscript-Object?
> - Investigations on the memory leaks. Both leaks shouldn't occure. (I'll do
> this, if I find time. but ...)
> - Fernando Simon: What about using OCI-Connection-Pooling for oracle
> instead the mappool.c?
> http://oraclesvca2.oracle.com/docs/cd/B14117_01/appdev.101/b10779/oci09adv.htm#452244
> (If you don't have time, I maybe could help coding. But would it become
> part uf Mapserver?)
> Happy new year to everybody
> Benedikt Rothe
