Strange dl("php_mapscript.so") behavior
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Thu Feb 16 11:09:50 EST 2006
Hi William,
happy that I was that my database was with your help up-and-running
again, I attacked my postgres plus now postgis conversion. And
whoops,... no more map display. I am shocked!! :-)
Ok, I tried it with only
dl("php_mapscript.so");
But in vain. Still same result. Nothing displays. Not even a simple
echo.
The apache and sys log don't give any results either. Once I had a
"LOG: unexpected EOF on client connection" displayed, but it
disappeared suddenly...
Gush, what is this magic, that makes disappear everything on my page?!?!
Stef
> Stefan, fancy seeing you over here...
> Does it work with just the dl("php_mapscript.so"); line? Since
> they're my Mac packages, I just want to make nothing is wrong there.
> I can't remember off the top of my head if PHP can handle single
> statements in if clauses without brackets. Just to be sure, try
> (or whatever your style is with bracket placement):
> if (PHP_OS == "WINNT" || PHP_OS == "WIN32") {
> dl("php_mapscript_44.dll");
> } else {
> Also, check the Apache and console/system logs for possible error
> messages that don't don't get displayed.
> On Feb 16, 2006, at 8:54 AM, Stefan Schwarzer wrote:
>> Hi,
>> I ran into a very strange thing:
>> I run the usual code to get the mapscript library:
>> else
>> If my php code is correct, everything displays nicely. But once
>> something is not correct - a semicolon missing, a bad syntax, etc.
>> - the page stays white. As soon as I take the four lines of code
>> away (especially the last one), it displays the error messages.
>> But this is bad, cause then all my mapscript-related stuff won't
>> work anymore...
>> Does anyone have an idea why this is?
>> Thanks for any hints,
>> Stef
>> PS: Just for the notes: I am running a Mac, with the kyngchaos
>> installation packages.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
