Strange dl("php_mapscript.so") behavior
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Thu Feb 16 11:49:16 EST 2006
No, it's not PHP. It's related with Mapserver. Actually, I have only
updated the gislibs and postgres with your packages. So, stupid me, I
haven't controlled the testphp.php - so there seems to be the
problem. I will update now all packages with your latest ones.... and
hopefully this helps!
Stef
> does the testphp.php work? (loads mapscript and calls phpinfo)
> I've had mysterious issues like this in the past. One correct line
> causes the whole thing to implode and disappear. Yet the problem
> turns out to be somewhere else. I've cleaned up code a bit and
> that helps. Let's see if I can remember...
> I hope we're not getting too far off topic here.
> The main thing I've found that tends to kill PHP is continuing
> lines. Like when you concatenate strings together (these are
> separate lines):
> $z = 'part of a string' . $somevariable .
> 'some more';
> I think this is correct PHP, PHP is supposed to keep going across
> line breaks until it find the semicolon to close the statement, and
> it works most of the time, but sometimes it's enough to kill PHP.
> If you need to break lines to make it more readable, close the
> statement and start again on the next line:
> $z = 'part of a string' . $somevariable;
> $z .= 'some more';
> On Feb 16, 2006, at 10:09 AM, Stefan Schwarzer wrote:
>> Hi William,
>> happy that I was that my database was with your help up-and-
>> running again, I attacked my postgres plus now postgis conversion.
>> And whoops,... no more map display. I am shocked!! :-)
>> Ok, I tried it with only
>> dl("php_mapscript.so");
>> But in vain. Still same result. Nothing displays. Not even a
>> simple echo.
>> The apache and sys log don't give any results either. Once I had a
>> "LOG: unexpected EOF on client connection" displayed, but it
>> disappeared suddenly...
>> Gush, what is this magic, that makes disappear everything on my
>> page?!?!
>> Stef
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "I ache, therefore I am. Or in my case - I am, therefore I ache."
> - Marvin
