Postgis and EXPRESSION
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Thu Feb 23 04:17:16 EST 2006
Stefan,
> So, meanwhile I have this definition:
> LAYER
> NAME bg_shape
> CONNECTIONTYPE postgis
> CONNECTION 'user=xxx password=xxx dbname=xxx'
> TYPE POLYGON
> DATA 'the_geom FROM countries_regions_view USING UNIQUE id USING
> srid=-1'
> CLASSITEM 'reg_name'
You definitely don't need a CLASSITEM when you use "logical" expressions
which directly reference some fields or attributes of your underlying
dataset, as you're doing. So, it's better to leave this one away.
> CLASS
> NAME ''
> EXPRESSION ([reg_name] ne 'Africa')
Don't forget to put quotes around [reg_name]. Aren't you trying to do a
string comparison between the value of reg_name and "Africa"? Well, then
you'll need them as Mapserver simply replaces [reg_name] with it's
actual value before evaluating the expression.
So, I suggest giving a try to somewhat like this:
EXPRESSION ('[reg_name]' ne 'Africa')
> OUTLINECOLOR 230 230 230
> COLOR 230 230 230
> END
> END
> and attached is a screenshot of the view.
Best regards,
Andreas
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web: www.territoriumonline.com
