Preventing browser refresh using Mapserver
Piero Cavalieri
piero.cavalieri at HEIDI.IT
Tue Feb 28 04:45:00 EST 2006
Yes, javascript XMLHttpRequest object. But you should find some library
to use for that (with .NET I use Ajax.NET). If you work with mapserver cgi
directly, response should return values you have in template file (which
doesn't have to be a complete HTML file, but only have values you want in
the []. Then you use this values in your javascript file, to set src
properties of main image and reference map, and all other relevant values
you want).
P.
Ben Crane ha scritto:
> Hi all,
> In Mapserver applications, is there anyway of stopped
> the page being refreshed every time a request is made
> to the server? I have heard of using XML HTTP Request
> Object?
> Regards
> Ben
