MSPOSTGISLayerOpen -- shared connection not available
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Tue Feb 28 23:50:10 PST 2006
On 2/28/06, Steve W <klawsteve at yahoo.com> wrote:
> Am unable to render a map with a POSTGIS layer.
> Archive and g**gle searches come up almost empty on this one.
> Architecture: ms4w/Apache 2.0.54/PHP4.3.11/mapserv4.6
> Layer exists, can be queried spatially and non-spatially outside of
> mapserver, and can be displayed in QuantumGIS. So I believe the data is fine.
> Map file snippet looks like this:
> LAYER
> NAME "country"
> CONNECTIONTYPE postgis
> CONNECTION "dbname=world user=postgres password=XXXXX server=localhost
> port=5432"
> DATA "geom from public.cntry2"
> DEBUG TRUE
> (or I can provide user=nobody)
> Apache error log looks like this:
> [error] [client 127.0.0.1] msPOSTGISLayerOpen called datastatement: geom
> from public.cntry2\r, referer: http://localhost/world/index.phtml
> [error] [client 127.0.0.1] MSPOSTGISLayerOpen -- shared connection not
> available.\r, referer: http://localhost/world/index.phtml
This is not an error, only a debug statement saying that the
connection pool has not a connection already available and that a new
one needs to be opened.
> [Tue Feb 28 14:09:40 2006] [error] [client 127.0.0.1]
> FAILURE!!!msPOSTGISLayerClose datastatement: geom from public.cntry2\r,
> [Tue Feb 28 14:09:40 2006] [error] [client 127.0.0.1] msPOSTGISLayerClose --
> layerinfo is NULL\r, referer: http://localhost/world/index.phtml
This should not be an error too.
I conclude it should be a problem with the postgis data? How did you
load it in postgres?
Best regards,
Umberto
> Found a suggestion to manipulate POSTGRESQL's pg_hba.conf configuration file
> to replace authorization 'md5' with 'trust' for all users on the localhost.
> However when doing so, either a)all connections to the postmaster fail; or
> b) problem continues.
> Have set the postgresql.conf listen_address variable = '*' as suggested to
> allow connections from all hosts.
> Thank you for any insights
> -steve
More information about the MapServer-users
