MSPOSTGISLayerOpen -- shared connection not available
Steve W
klawsteve at YAHOO.COM
Tue Feb 28 17:32:32 EST 2006
Am unable to render a map with a POSTGIS layer.
Archive and g**gle searches come up almost empty on this one.
Architecture: ms4w/Apache 2.0.54/PHP4.3.11/mapserv4.6
Layer exists, can be queried spatially and non-spatially outside of
mapserver, and can be displayed in QuantumGIS. So I believe the data is fine.
Map file snippet looks like this:
LAYER
NAME "country"
CONNECTIONTYPE postgis
CONNECTION "dbname=world user=postgres password=XXXXX server=localhost
port=5432"
DATA "geom from public.cntry2"
DEBUG TRUE
(or I can provide user=nobody)
Apache error log looks like this:
[error] [client 127.0.0.1] msPOSTGISLayerOpen called datastatement: geom
from public.cntry2\r, referer: http://localhost/world/index.phtml
[error] [client 127.0.0.1] MSPOSTGISLayerOpen -- shared connection not
available.\r, referer: http://localhost/world/index.phtml
[Tue Feb 28 14:09:40 2006] [error] [client 127.0.0.1]
FAILURE!!!msPOSTGISLayerClose datastatement: geom from public.cntry2\r,
[Tue Feb 28 14:09:40 2006] [error] [client 127.0.0.1] msPOSTGISLayerClose --
layerinfo is NULL\r, referer: http://localhost/world/index.phtml
Found a suggestion to manipulate POSTGRESQL's pg_hba.conf configuration file
to replace authorization 'md5' with 'trust' for all users on the localhost.
However when doing so, either a)all connections to the postmaster fail; or
b) problem continues.
Have set the postgresql.conf listen_address variable = '*' as suggested to
allow connections from all hosts.
Thank you for any insights
-steve
