converting shp to tab loses projection
Xin
crazygecko at GMAIL.COM
Mon Jan 9 06:18:34 EST 2006
Hi list,
I have a shapefile containing points in the UK. I need the file in MapInfo
TAB format. After converting, the projection seems to have been lost.
I have tried various ways of reprojecting in the hope the final TAB file
will have them, but none seem to work so far.
I have created a VRT file for the shapefile, with projection specified as
<LayerSRS>WGS84</LayerSRS>. Converted to tab file using the command
'ogr2ogr -t_srs "+init=epsg:4326" sample.tab sample.vrt
epsg 4326 is latlong WGS84.
This didn't work. Neither did specifying the full datum for latlong WGS84.
I then tried to convert from shp to tab and reprojecting at the same time.
And then I tried to reproject the shapefile to shape again, then convert
this shape to tab. None of these attempts worked.
Can anyone shed some light on this please?
Cheers,
Xin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060109/590ff6ed/attachment.html
