ogr2ogr works on Linux, does not on Windows
Xin
crazygecko at GMAIL.COM
Mon Jan 9 07:57:46 EST 2006
Hi list,
I am trying to convert a shapefile to tabfile whilst reprojecting it to
LatLong WGS84. This works great on Linux, but doesn't on Windows.
The command used is:
ogr2ogr -f "MapInfo File" address.tab address.shp -t_srs "+proj=longlat
+ellps=WGS84 +datum=WGS84 +no_defs" -s_srs "+proj=longlat +ellps=WGS84
I did initially use EPSG codes, but that didn't work on Windows so I thought
I'd try the actual datum codes. No luck.
There are no error produced on Windows. On opening the TAB file it is not
projected.
I am using the latest FWTools.
If information is greatly appreciated.
Cheers,
Xin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060109/b3a105fd/attachment.html
