Map not rendering
James Net
james_marsnett at HOTMAIL.COM
Mon Jan 9 15:05:05 PST 2006
Thanks Hester,
Alas that did not fix my problem. My WMS works and has always worked - I'm
not asking 'bout that.
This renders my map, using a wms:
http://myserver/cgi-bin/mapserv?map=/var/www/html/workshop/start3.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=mymap
So why won't this work (with the same .map file), just to test and debug:
http://myserver/cgi-bin/mapserv?map=/var/www/html/workshop/start3.map&mode=map
And I HAVE CHANGED my only layer to status DEFAULT!
I have done this before using a .shp file (tiled raster), and it works:
http://myserver/cgi-bin/mapserv?map=/var/www/html/workshop/start2.map&mode=map
So what have I done wrong?
James
>From: "Hester Jane Viola" <H.Viola at bom.gov.au>
>To: "James Net" <james_marsnett at HOTMAIL.COM>
>CC: <MAPSERVER-USERS at LISTS.UMN.EDU>
>Subject: RE: [UMN_MAPSERVER-USERS] Map not rendering
>Date: Mon, 9 Jan 2006 14:17:38 +1100
>Hi,
>The problem is easily solved.
>Your request does actually work, in that it returns an image, but will not
>render any layers unless you set them to be drawn by default.
>using : STATUS DEFAULT
>Have a look at the following:
>Copyright layer only (which has STATUS DEFAULT)
>http://www4.bom.gov.au/cgi-bin/mapserver/mapserv?map=%2Fweb%2Fhtdocs%2Fmapserver%2Fweather.map&mode=map
>and
>http://www4.bom.gov.au/cgi-bin/mapserver/mapserv?map=/web/htdocs/mapserver/weather.map&version=1.1.1&service=WMS&request=GetMap&layers=copyright&SRS=EPSG:4283&bbox=111,-48.3,158,-4.2&transparent=true
>versus:
>Copyright and coast (though copyright is not required in either request,
>but it is still returned)
>http://www4.bom.gov.au/cgi-bin/mapserver/mapserv?map=/web/htdocs/mapserver/weather.map&version=1.1.1&service=WMS&request=GetMap&layers=coast&SRS=EPSG:4283&bbox=111,-48.3,158,-4.2&transparent=true
>and
>http://www4.bom.gov.au/cgi-bin/mapserver/mapserv?map=%2Fweb%2Fhtdocs%2Fmapserver%2Fweather.map&mode=map&layer=coast
>Hope that makes sense
>Cheers
>Hester
>http://www4.bom.gov.au/mapserver
>Regards
>Hester VIOLA
>IT Officer, Data Management
>Bureau of Meteorology
>700 Collins St, Melbourne
>Australia, 3008
>Email. h.viola at bom.gov.au
>Ph. 61 39669-4403 (w)
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
>Behalf Of James Net
>Sent: Monday, 9 January 2006 1:49 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] Map not rendering
>Hi all,
>While I hope this is not a silly question, I fear it is, or at least would
>have a simple solution.
>I am trying to render a map with ms.
>If I do the following, the map renders and all is fine:
>However, if I try the following, nothing is rendered - just a solid white
>square:
>I'm just using a simple map file:
>MAP
> NAME TEST
> IMAGETYPE jpeg
> EXTENT 140 -40 150 -33
> SIZE 600 600
> #SHAPEPATH "/home/data/map/Landsat Mosaic TM2000/GDA94LL/"
> DEBUG ON
># TEMPLATEPATTERN 'start'
>WEB
> TEMPLATE 'start_template.html'
> IMAGEPATH '/var/www/html/tmp/'
> IMAGEURL '/tmp/'
>END
>PROJECTION
> "init=epsg:4283" #required
>END
>LAYER
> NAME "mymap"
> DATA "mymap_mosaic_murray_geov2_WGS84.tif"
> TYPE RASTER
> STATUS ON
>END
>END
>Is this odd? Shouldn't both URL's work?
>I've also tried shp2img and the map correctly renders.
>So why doesn't this work?:
>I'm using map server on redhat.
>Thanks in advance.
>_________________________________________________________________
>Make your dream car a reality
>http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Fcarpoint%2Eninemsn%2Ecom%2Eau&_t=12345&_r=emailtagline&_m=EXT
realestate.com.au: the biggest address in property
http://ninemsn.realestate.com.au
More information about the MapServer-users
