Map not rendering
James Net
james_marsnett at HOTMAIL.COM
Mon Jan 9 16:07:34 PST 2006
Problem Solved. It was that darn STATUS: DEFAULT.
Thanks again
>From: "Ed McNierney" <ed at topozone.com>
>To: "James Net"
><james_marsnett at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
>Subject: RE: [UMN_MAPSERVER-USERS] Map not rendering
>Date: Sun, 8 Jan 2006 22:21:44 -0500
>James -
>Set your layer to STATUS DEFAULT, instead of STATUS ON. The WMS request
>forces that layer to be displayed, since you must list it explicitly.
>STATUS ON does not mean what you and 98,274 other new users (myself
>included) thinks it means!
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA 01863
>Phone: +1 (978) 251-4242
>Fax: +1 (978) 251-1396
>ed at topozone.com
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>Behalf Of James Net
>Sent: Sunday, January 08, 2006 9:49 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] Map not rendering
>Hi all,
>While I hope this is not a silly question, I fear it is, or at least
>would have a simple solution.
>I am trying to render a map with ms.
>If I do the following, the map renders and all is fine:
>http://myserver/cgi-bin/mapserv?map=/var/www/html/workshop/start3.map&SE
>RVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=mymap
>However, if I try the following, nothing is rendered - just a solid
>white
>square:
>http://myserver/cgi-bin/mapserv?map=/var/www/html/workshop/start3.map&mo
>de=map
>I'm just using a simple map file:
>MAP
> NAME TEST
> IMAGETYPE jpeg
> EXTENT 140 -40 150 -33
> SIZE 600 600
> #SHAPEPATH "/home/data/map/Landsat Mosaic TM2000/GDA94LL/"
> DEBUG ON
># TEMPLATEPATTERN 'start'
>WEB
> TEMPLATE 'start_template.html'
> IMAGEPATH '/var/www/html/tmp/'
> IMAGEURL '/tmp/'
>END
>PROJECTION
> "init=epsg:4283" #required
>END
>LAYER
> NAME "mymap"
> DATA "mymap_mosaic_murray_geov2_WGS84.tif"
> TYPE RASTER
> STATUS ON
>END
>END
>Is this odd? Shouldn't both URL's work?
>I've also tried shp2img and the map correctly renders.
>So why doesn't this work?:
>de=map
>I'm using map server on redhat.
>Thanks in advance.
>_________________________________________________________________
>Make your dream car a reality
>http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Fcarpoint%2Eninemsn%2Ecom
>%2Eau&_t=12345&_r=emailtagline&_m=EXT
ASUS M5 Ultra-slim lightweight is Now $1999 (was $2,999)
http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Fwww%2Easus%2Ecom%2Eau%2F&_t=752129232&_r=Hotmail_tagline_23Nov05&_m=EXT
More information about the MapServer-users
