Problem in Oracle Spatial Connection - Empty Image
Bart van den Eijnden (OSGIS) bartvde at XS4ALL.NL
Tue Jan 10 08:48:32 PST 2006
Try to put debugging on, that might give us some clues. See:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?DebuggingMapserver
Best regards,
Bart
Prema Selvam (sent by Nabble.com) wrote:
> Hi Everybody,
>  I am new to the MapServer, my actual problem is in establishing
> connection between MapServer and Oracle Spatial.
>  When i pass the query(shown below) the empty image is displayed in
> the browser without any map
> /http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/sdocountry/sdocountry.map&layers=country&mode=map
> <http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/sdocountry/sdocountry.map&layers=country&mode=map>/
>  I Created .map file (shown below) with the Oracle Spatial Connection.
>         MAP
>                 STATUS ON
>                 SIZE 800 600
>                 UNITS dd
>                 IMAGECOLOR 255 255 255
>                 PROJECTION
>                         "proj=latlong"
>                         "ellps=WGS84"
>                 END
>                 EXTENT -180 -45 180 45
>                 LAYER
>                         PROJECTION
>                                 "proj=latlong"
>                                 "ellps=WGS84"
>                         END
>                         NAME "CountryMap"
>                         TYPE POLYGON
>                         CONNECTIONTYPE oraclespatial
>                         CONNECTION "world/land at orcl"
>                         DATA "shape FROM country USING SRID 8307"
>                         CLASS
>                                 NAME "Country_Class"
>                                 STYLE
>                                         COLOR 250 250 0
>                                         OUTLINECOLOR 32 32 32
>                                 END
>                         END
>                 END
>         END
>  And Set the environment variable in the apache/conf/httpd.conf file as
>         SetEnv ORACLE_BASE "d:/oracle/product/10.2.0"
>         SetEnv ORACLE_HOME "d:/oracle/product/10.2.0/db_1"
>         SetEnv ORACLE_SID "orcl"
>         SetEnv TNS_ADMIN "d:/oracle/product/10.2.0/db_1/network/admin"
> This is the my whole Sample code and configuration, I dont know why
> the map image is not generating.
> I am not receving any error message.
> MapServer for windows (ms4w) binaries is downloaded from "maptools.org"
> System configuration
>         Windows 2000 Advanced Server
>         Oracle 10g
>         MapServer 4.6.1
>         Apache/2.0.55 (Win32)
> I am waiting for the some solution, from you to over come this problem.
> Thanks & Regards,
> Prema Selvam.
> View this message in context: Problem in Oracle Spatial Connection -
> Empty Image
> <http://www.nabble.com/Problem-in-Oracle-Spatial-Connection---Empty-Image-t888093.html#a2301886>
> Sent from the Mapserver - User
> <http://www.nabble.com/Mapserver---User-f1215.html> forum at Nabble.com.
OSGIS, Open Source GIS
http://www.osgis.nl
More information about the MapServer-users mailing list
