POSTLABELCACHE with BACKGROUNDCOLOR bug?
Vito Meuli
vito.meuli at TECNOLOGIEAVANZATE.IT
Wed Jan 11 10:05:11 EST 2006
I have a problem using "POSTLABELCACHE true" in a LAYER, because it doesn't
draw the billboard around labels anymore, which should display using the
BACKGROUNDCOLOR directive.
I send data to the layer via an url (it works well, displaying the billboard,
if I comment the POSTLABELCACHE directive out).
I can let the label become more evident using OUTLINECOLOR, but it's not the
same as the BACKGROUNDCOLOR.
The layer is as follows:
LAYER # layer delle scritte fisse sulla mappa
NAME "scritta"
METADATA
cliccabile "NO"
visibilita ""
END
TYPE annotation
STATUS default
TRANSFORM false
POSTLABELCACHE true
CLASS
LABEL
COLOR 188 0 44
#OUTLINECOLOR 255 255 255
BACKGROUNDCOLOR 255 255 255
TYPE TRUETYPE
FONT trebuchet_ms
SIZE 8
ANTIALIAS TRUE
POSITION ur
PARTIALS true
BUFFER 2
FORCE true
END # end of label
END
END # layer delle scritte fisse sulla mappa
I guess it is a bug. Is there any workaround?
Thank you in advance!
Vito
