Problem in Oracle Spatial Connection - Empty Image
Prema Selvam (sent by Nabble.com)
lists at NABBLE.COM
Wed Jan 11 10:51:03 EST 2006
Thanks,
When i run the mapserv.exe in the command mode as mapserv - v i found that there is no support for the Oracle Spatial as given below
C:\ms4w\Apache\cgi-bin>mapserv -v
MapServer version 4.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPO
RTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT
=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
I downloaded the arcadis.zip from http://www.osgis.nl/arcadis.zip as per your suggestion
when i unzipped i found the following files (7 files) in alphabetical order
1. bgd.dll
2. gdal13.dll
3. libmap.dll
4. mapserv.exe
5. msvcp80.dll
6. msvcr80.dll
7. proj.dll
When i run the downloaded mapserv.exe in the command mode as mapserv - v i found support for the Oracle Spatial in INPUT
C:\MapServer\arcadis>mapserv -v
MapServer version 4.8.0-rc1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT
=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUP
PORTS=WCS_SERVER INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=
MSDEBUG
Now my Question is where i need to put all the 7 files which i downloaded, whether i need to overwrite the existing with new file.
And proj.dll file was not in the ..\apache\cgi-bin folder it was in the ..\ms4w\proj whether i need to ovewrite that file also or i need to put the new proj.dll in the ..\apache\cgi-bin .
And there are four new files which is
bgd.dll
libmap.dll
msvcp80.dll
msvcr80.dll
where i need to put all these four files and the remaining three files.
Please give me a some solution
Waiting for the reply.
Thanks & Regards,
Prema Selvam.
View this message in context: http://www.nabble.com/Problem-in-Oracle-Spatial-Connection---Empty-Image-t888093.html#a2321776
Sent from the Mapserver - User forum at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060111/6c04cbab/attachment.html
