Problem in Oracle Spatial Connection - Empty Image
Ruiter E. de (Erik)
E.Ruiter at ARCADIS.NL
Wed Jan 11 11:08:53 EST 2006
you should place the dll's in /ms4w/apache/cgi-bin directory overwriting
when necessary. About the proj.dll I'm not sure but I placed it in
cgi-bin as wel as in the proj directory.
It works for me...
Also I have copied (I read somewhere this is needed) the proj directory
placing it my root (C:), again, I'm not sure this is needed...
good luck!
Erik.
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Prema Selvam (sent by Nabble.com)
Sent: woensdag 11 januari 2006 16:51
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Problem in Oracle Spatial Connection
- Empty Image
Thanks,
When i run the mapserv.exe in the command mode as mapserv - v i found
that there is no support for the Oracle Spatial as given below
C:\ms4w\Apache\cgi-bin>mapserv -v
MapServer version 4.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPO
RTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER INPUT
=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
I downloaded the arcadis.zip from http://www.osgis.nl/arcadis.zip as
per your suggestion
when i unzipped i found the following files (7 files) in alphabetical
order
1. bgd.dll
2. gdal13.dll
3. libmap.dll
4. mapserv.exe
5. msvcp80.dll
6. msvcr80.dll
7. proj.dll
When i run the downloaded mapserv.exe in the command mode as mapserv -
v i found support for the Oracle Spatial in INPUT
C:\MapServer\arcadis>mapserv -v
MapServer version 4.8.0-rc1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT
=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
PORTS=WCS_SERVER INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL
MSDEBUG
Now my Question is where i need to put all the 7 files which i
downloaded, whether i need to overwrite the existing with new file.
And proj.dll file was not in the ..\apache\cgi-bin folder it was in the
..\ms4w\proj whether i need to ovewrite that file also or i need to put
the new proj.dll in the ..\apache\cgi-bin .
And there are four new files which is
bgd.dll
libmap.dll
msvcp80.dll
msvcr80.dll
where i need to put all these four files and the remaining three files.
Please give me a some solution
Waiting for the reply.
Thanks & Regards,
Prema Selvam.
View this message in context: Re: Problem in Oracle Spatial Connection -
Empty Image
<http://www.nabble.com/Problem-in-Oracle-Spatial-Connection---Empty-Imag
e-t888093.html#a2321776>
Sent from the Mapserver - User
<http://www.nabble.com/Mapserver---User-f1215.html> forum at
Nabble.com.
[DISCLAIMER]
Dit e-mail bericht is vertrouwelijk. Het is uitsluitend bestemd voor de geadresseerde.
Indien u niet de geadresseerde bent, verzoeken we u dringend ons direct te informeren en om dit bericht en eventuele bijlage(n) te verwijderen, zonder het te kopieren, door te zenden of op enige andere wijze te openbaren of te gebruiken. ARCADIS is niet aansprakelijk voor welke schade dan ook als gevolg van communicatie per e-mail en verzending van documenten en gegevens.
This e-mail is confidential and may also be privileged. It is intended for use by the addressee only.
If you are not the intended addressee, we request that you notify us immediately and delete this e-mail, and any attachment(s), without copying, forwarding, disclosing or using it in any other way. ARCADIS will not be liable for damage relating to the communication by e-mail of data or documents.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060111/494b58ce/attachment.html
