layer grouping
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Wed Jan 11 19:00:09 EST 2006
Hi Laura,
have a look at the *wms_layer_group *metadata, which can take an xpath
like expression for you to define a hierarchy, see also:
http://mapserver.gis.umn.edu/docs/howto/wms_server
Best regards,
Bart
Laura Díaz wrote:
>Hi there,
>i am trying to configure some available layers in mapserver, i would like to group some
>of them, i found no problem creating just one grouping level:
><Layer>
> <Layer>
> </Layer>
> <Layer>
> </Layer>
></Layer>
>for this i just add the TAG GROUP to the layers i want to group, the problem comes
>when i want to configure two or more levels like this:
><Layer>
> <Layer>
> <Layer>
> </Layer>
> </Layer>
> <Layer>
> </Layer>
></Layer>
>My problem comes because the layer that groups a set of layers is not a layer itself so i
>cant make a reference to it, if i create a layer as a LAYER to be the GROUP of some
>sublayers, then this layer appears two times in the capabilities.
>any ideas to create this second level of layer grouping??
>here part of the layers definition on my map file:
>#LAYER
># NAME ProtectedAreas
># METADATA
># "wms_title" "Protected Areas"
># END
># STATUS OFF
># TYPE ANNOTATION
>#END
>LAYER
> NAME zepa
> GROUP ProtectedAreas
> METADATA
> "wms_title" "Zepa zones"
> "wms_group_title" "Protected Areas"
> gml_include_items "all"
> END
> STATUS ON
> TYPE POLYGON
> DUMP TRUE
> PROJECTION
> "init=epsg:23030"
> END
> CONNECTIONTYPE postgis
> CONNECTION "user=***** password=***** dbname=costas host=192.168.0.0"
> DATA "the_geom from (select * from zepa) as foo using unique gid = using
>SRID=23030"
> TOLERANCE 3
> CLASS
> NAME "zepa"
> TEMPLATE 'gmap/htdocs/templates/popplace.html'
> COLOR 0 240 240
> OUTLINECOLOR 199 199 199
> END
>END
>LAYER
> NAME mreservas
> METADATA
> "wms_title" "Microreservas"
> END
> STATUS ON
> TYPE POLYGON
> DUMP TRUE
> PROJECTION
> "init=epsg:23030"
> END
> DATA "the_geom from (select * from mreservas) as foo using unique gid = using
>SRID=23030"
> TOLERANCE 3
> CLASS
> NAME "mreservas"
> COLOR 0 240 240
> END
>END
>thanks,
>Laura.
OSGIS, Open Source GIS
http://www.osgis.nl
