MapServer/SSL/Certificates
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Thu Jan 12 12:54:27 EST 2006
check this page:
http://curl.haxx.se/docs/sslcerts.html
Maybe setting the following environment variable to your certifcates
directory might do the trick, I haven't tried this though. Are you using
IIS? Then set the system environment variable and restart the server. If
you are using Apache use SetEnv in the conf file and restart Apache.
CURL_CA_BUNDLE
Best regards,
Bart
Reuel Villaflor wrote:
> Hello.
> I’ve got MapServer 4.6.1 installed on a Windows 2k3 box. The
> installation was the binary installation, downloaded from MapServer
> website. I’m trying to grab a layer from a WMS which requires
> authentication using a digital certificate.
> My browser has the CA and client certificates installed, but it looks
> as though that’s not good enough for MapServer – my guess is that
> MapServer’s use of libcurl precludes any certificate registration done
> in the browser?
> Anyway, has anyone been able to use MapServer to access a WMS that
> requires certificates, and if so, could you point me to some
> additional information? Would this be as simple as fixing a *.map
> file, or would it be much more involved, such as recompiling, etc.?
> Thanks for any help.
> -R
OSGIS, Open Source GIS
http://www.osgis.nl
