Mapfile - 50 Layers Maximum ?
Randy How
rhow at I3.COM
Fri Jan 13 09:51:13 PST 2006
Greetings,
I've come across this rumor/fact, that there is a maximum of 50 layers in a
map file. Unknowingly I was experimenting the use of MapServer for QC'ing
a project, that I put in 2,500 layers into a mapfile. Yes, not surprisingly
MapServer baucked about this. Then the first question is what is the limit,
then I found out that it was 50!
I looked in to an existing mapfile that we have and it has 45 layers. These
layers are represented at different scales, and/or by spatial reference
(i.e. Indices for different UTM zones), then a watermark.
We are moving into more global datasets which may be represented the same
way. There's 60 UTM zones. So the 50 layer limit is going to be a problem
in the short term.
Can anyone verify this fact? And is there a work around in place to
accomplish these needs?
Thanks, Randy
________________________________________________
Randy How
Geospatial Applications Developer
Voice: +1-970-482-4400
Fax: +1-970-482-4499
Web: http://www.i3.com/
i-cubed
201 Linden, Third Floor
Fort Collins, CO 80524
More information about the MapServer-users
