Mapfile - 50 Layers Maximum ?
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Jan 13 13:09:51 EST 2006
Randy,
The limit is set in map.h
You can change the limit and recompile
More resent version have a higher limit I think, but I'm not sure what.
-Steve W.
Randy How wrote:
> Greetings,
> I've come across this rumor/fact, that there is a maximum of 50 layers in a
> map file. Unknowingly I was experimenting the use of MapServer for QC'ing
> a project, that I put in 2,500 layers into a mapfile. Yes, not surprisingly
> MapServer baucked about this. Then the first question is what is the limit,
> then I found out that it was 50!
> I looked in to an existing mapfile that we have and it has 45 layers. These
> layers are represented at different scales, and/or by spatial reference
> (i.e. Indices for different UTM zones), then a watermark.
> We are moving into more global datasets which may be represented the same
> way. There's 60 UTM zones. So the 50 layer limit is going to be a problem
> in the short term.
> Can anyone verify this fact? And is there a work around in place to
> accomplish these needs?
> Thanks, Randy
> ________________________________________________
> Randy How
> Geospatial Applications Developer
> Voice: +1-970-482-4400
> Fax: +1-970-482-4499
> Web: http://www.i3.com/
> i-cubed
> 201 Linden, Third Floor
> Fort Collins, CO 80524
