Mapfile - 50 Layers Maximum ?
Brent Fraser
bfraser at GEOANALYTIC.COM
Fri Jan 13 13:23:13 EST 2006
Randy,
I've done some work with global datasets as well. I made a few changes
to (my own copy of) mapraster.c to use a Lat/Lon tileindex along with
automatically using the SRS of the underlying raster files. This allowed me
to have one layer for 60 zones worth of raster data.
I wsa reluctant to submit the changes since I didn't do the changes for
vector tiles, and the testing was minimal. But I'm open to it if other
people would find it useful....
Brent Fraser
GeoAnalytic Inc
Calgary, Alberta
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, January 13, 2006 10:51 AM
Subject: [UMN_MAPSERVER-USERS] Mapfile - 50 Layers Maximum ?
> Greetings,
> I've come across this rumor/fact, that there is a maximum of 50 layers in
a
> map file. Unknowingly I was experimenting the use of MapServer for
QC'ing
> a project, that I put in 2,500 layers into a mapfile. Yes, not
surprisingly
> MapServer baucked about this. Then the first question is what is the
limit,
> then I found out that it was 50!
> I looked in to an existing mapfile that we have and it has 45 layers.
These
> layers are represented at different scales, and/or by spatial reference
> (i.e. Indices for different UTM zones), then a watermark.
> We are moving into more global datasets which may be represented the same
> way. There's 60 UTM zones. So the 50 layer limit is going to be a
problem
> in the short term.
> Can anyone verify this fact? And is there a work around in place to
> accomplish these needs?
> Thanks, Randy
> ________________________________________________
> Randy How
> Geospatial Applications Developer
> Voice: +1-970-482-4400
> Fax: +1-970-482-4499
> Web: http://www.i3.com/
> i-cubed
> 201 Linden, Third Floor
> Fort Collins, CO 80524
