Mapfile - 50 Layers Maximum ?
James Net
james_marsnett at HOTMAIL.COM
Fri Jan 13 20:36:21 EST 2006
Sorry to butt in, but does changing the max limit in "map.h" (to say 1000)
and then recompiling have any effect on the speed / efficiency of mapserver
if you have have a map file wth only 1 - 5 layers?
>From: Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>
>Reply-To: Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Mapfile - 50 Layers Maximum ?
>Date: Fri, 13 Jan 2006 13:09:51 -0500
>Randy,
>The limit is set in map.h
>You can change the limit and recompile
>More resent version have a higher limit I think, but I'm not sure what.
>-Steve W.
>Randy How wrote:
>> Greetings,
>> I've come across this rumor/fact, that there is a maximum of 50 layers
>>in a
>>map file. Unknowingly I was experimenting the use of MapServer for
>>QC'ing
>>a project, that I put in 2,500 layers into a mapfile. Yes, not
>>surprisingly
>>MapServer baucked about this. Then the first question is what is the
>>limit,
>>then I found out that it was 50!
>> I looked in to an existing mapfile that we have and it has 45 layers.
>>These
>>layers are represented at different scales, and/or by spatial reference
>>(i.e. Indices for different UTM zones), then a watermark.
>> We are moving into more global datasets which may be represented the
>>same
>>way. There's 60 UTM zones. So the 50 layer limit is going to be a
>>problem
>>in the short term.
>> Can anyone verify this fact? And is there a work around in place to
>>accomplish these needs?
>> Thanks, Randy ________________________________________________
>>Randy How
>>Geospatial Applications Developer
>>Voice: +1-970-482-4400
>>Fax: +1-970-482-4499
>>Web: http://www.i3.com/
>>i-cubed
>>201 Linden, Third Floor
>>Fort Collins, CO 80524
_________________________________________________________________
ASUS M5 Ultra-slim lightweight is Now $1999 (was $2,999)
http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Fwww%2Easus%2Ecom%2Eau%2F&_t=752129232&_r=Hotmail_tagline_23Nov05&_m=EXT
