Mapserver compile error on Ubuntu
Matthew Perry perrygeo at GMAIL.COM
Sun Jan 15 15:49:23 PST 2006
Perry,
On 1/15/06, Pericles S. Nacionales <naci0002 at umn.edu> wrote:
> What happens if you run configure with this:
> ./configure --with-wmsclient --with-wfsclient --with-gdal=/usr/local/bin/gdal-config --with-ogr --with-proj
> (Don't pass the path to "--with-ogr" parameter).
Same error. I tried without specifying any paths and tried specifying
the the official ubuntu gdal binaries in /usr/bin with the same
results.
matt
> Matthew Perry wrote:
> >Hey folks,
> >  I'm installing mapserver 4.6.2 from source on ubuntu breezy and I'm
> >running into some errors. I built most dependencies with "apt-get
> >build-dep mapserver-bin", built my own gdal cvs (from 01/11/06) in
> >/usr/local and configured with:
> >--with-gdal=/usr/local/bin/gdal-config --with-proj
> >--with-ogr=/usr/local/bin/gdal-config
> >But make is giving me the following errors:
> >gcc -O2 -fPIC -Wall   -DIGNORE_MISSING_DATA  -DNEED_STRLCAT
> >-DUSE_EPPL -DUSE_PROJ -DUSE_WMS_SVR -DUSE_WMS_LYR  -DUSE_WFS_LYR
> >-DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> >-DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS    -DUSE_OGR -DUSE_GDAL
> > -DUSE_ICONV        -DUSE_ZLIB -I/usr/include  -I/usr/local/include
> >      shp2img.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype
> >-lpng -lz -lXpm -lX11   -ljpeg -lfreetype -lpng -lz -lXpm -lX11
> >-lproj -ljpeg  -L/usr/local/lib -lgdal    -L/usr/lib -lcurl -lidn
> >-lssl -lcrypto -ldl -lssl -lcrypto -ldl -lz     -lc  -lz -lm -lstdc++
> >-o shp2img
> >./libmap.a(mapogr.o): In function `msOGRFileWhichShapes(layer_obj*,
> >rectObj, ms_ogr_file_info_t*)':
> >mapogr.cpp:(.text+0x516): undefined reference to
> >`OGRLineString::setPoint(int, double, double)'
> >mapogr.cpp:(.text+0x52e): undefined reference to
> >mapogr.cpp:(.text+0x54c): undefined reference to
> >mapogr.cpp:(.text+0x56a): undefined reference to
> >mapogr.cpp:(.text+0x582): undefined reference to
> >collect2: ld returned 1 exit status
> >make: *** [shp2img] Error 1
> >I've tried this on two other installations of Ubuntu and get the exact
> >same error even when compiling against older versions of gdal which I
> >know to be stable. If i compile without gdal/ogr it works fine. Does
> >anyone have any hints about where I can begin debugging this?
> >Matt Perry
> >perrygeo at gmail.com
> >http://www.perrygeo.net
Matt Perry
More information about the MapServer-users mailing list
