Mapserver compile error on Ubuntu
Till Adams adams at TERRESTRIS.DE
Mon Jan 16 00:22:00 PST 2006
Dear Perry,
we love Ubuntu because we never got less errors while compiling UMN (none).
We take all the libs from breezy (also libgdal and libgdal-dev) and
compile like this:
# ./configure --with-gd -- with-gdal=/usr/bin/gdal-config --with-ogr
--with-wms...
and all the rest we want without giving any pathes. If you make
# find -name gdal-config
it is located in "/usr/bin/"
Everything Works. Did you take any of the libs (gdal, gd, freetype, ..)
from sources and not as
package?
Till
Matthew Perry schrieb:
>Perry,
>On 1/15/06, Pericles S. Nacionales <naci0002 at umn.edu> wrote:
>>What happens if you run configure with this:
>>./configure --with-wmsclient --with-wfsclient --with-gdal=/usr/local/bin/gdal-config --with-ogr --with-proj
>>(Don't pass the path to "--with-ogr" parameter).
>Same error. I tried without specifying any paths and tried specifying
>the the official ubuntu gdal binaries in /usr/bin with the same
>results.
>matt
>>Matthew Perry wrote:
>>>Hey folks,
>>> I'm installing mapserver 4.6.2 from source on ubuntu breezy and I'm
>>>running into some errors. I built most dependencies with "apt-get
>>>build-dep mapserver-bin", built my own gdal cvs (from 01/11/06) in
>>>/usr/local and configured with:
>>>--with-gdal=/usr/local/bin/gdal-config --with-proj
>>>--with-ogr=/usr/local/bin/gdal-config
>>>But make is giving me the following errors:
>>>gcc -O2 -fPIC -Wall   -DIGNORE_MISSING_DATA  -DNEED_STRLCAT
>>>-DUSE_EPPL -DUSE_PROJ -DUSE_WMS_SVR -DUSE_WMS_LYR  -DUSE_WFS_LYR
>>>-DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
>>>-DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS    -DUSE_OGR -DUSE_GDAL
>>>-DUSE_ICONV        -DUSE_ZLIB -I/usr/include  -I/usr/local/include
>>>     shp2img.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype
>>>-lpng -lz -lXpm -lX11   -ljpeg -lfreetype -lpng -lz -lXpm -lX11
>>>-lproj -ljpeg  -L/usr/local/lib -lgdal    -L/usr/lib -lcurl -lidn
>>>-lssl -lcrypto -ldl -lssl -lcrypto -ldl -lz     -lc  -lz -lm -lstdc++
>>>-o shp2img
>>>./libmap.a(mapogr.o): In function `msOGRFileWhichShapes(layer_obj*,
>>>rectObj, ms_ogr_file_info_t*)':
>>>mapogr.cpp:(.text+0x516): undefined reference to
>>>`OGRLineString::setPoint(int, double, double)'
>>>mapogr.cpp:(.text+0x52e): undefined reference to
>>>mapogr.cpp:(.text+0x54c): undefined reference to
>>>mapogr.cpp:(.text+0x56a): undefined reference to
>>>mapogr.cpp:(.text+0x582): undefined reference to
>>>collect2: ld returned 1 exit status
>>>make: *** [shp2img] Error 1
>>>I've tried this on two other installations of Ubuntu and get the exact
>>>same error even when compiling against older versions of gdal which I
>>>know to be stable. If i compile without gdal/ogr it works fine. Does
>>>anyone have any hints about where I can begin debugging this?
>>>Matt Perry
>>>perrygeo at gmail.com
>>>http://www.perrygeo.net
>Matt Perry
*  released: AmeiN! ArcMap-Export-2-UMN  *
*        LiveLinux 'WebGIS on CD'        *
*        http://www.terrestris.de        *
Dipl. Geogr. Till Adams
terrestris, H. Paulsen& T. Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * http://www.terrestris.de
More information about the MapServer-users mailing list
