No reprojection done
Nilsson Bengt
bengt.nilsson at AEROTECHTELUB.SE
Sun Jan 15 18:38:22 EST 2006
I've set up a WMS server with an initial singe layer to test reprojection. However , I can't get the projection to work. Whatever output projection i try I get the same geographical (4326) back. For example, when I make a WMS request with SRS=EPSG:54004 (Mercator) and bounding box in that projection I get an 4326-map back. I do not get any errors. Here is my map-file:
MAP
NAME WMS-test
STATUS ON
SHAPEPATH "shp"
IMAGECOLOR 255 255 255
FONTSET ../etc/fontset.txt
DEBUG ON
WEB
LOG "/tmp/mapserv.log"
IMAGEPATH "/srv/www/htdocs/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "Test"
"wms_onlineresource" "http://hhhhhhhhh/mapserv/wt?service=WMS"
"wms_srs" "epsg:9823 epsg:4326 epsg:54004"
END
END
PROJECTION
"init=epsg:54004"
END
LAYER
NAME k92_strandlinje
DEBUG ON
METADATA
"wms_title" "k92_strandlinje"
"wms_srs" "EPSG:4326"
END
TYPE POLYGON
STATUS ON
CONNECTIONTYPE postgis
CONNECTION "user=postgres password=xxx dbname=xxx host=localhost"
DATA 'the_geom from k92_strandlin_polygon'
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "strandlin-pgx"
COLOR 255 251 237
OUTLINECOLOR 100 100 100
END
END
END
/Regards Bengt
