Mapserver compile error on Ubuntu
Frank Warmerdam
warmerdam at POBOX.COM
Mon Jan 16 08:49:57 EST 2006
On 1/16/06, Matthew Perry <perrygeo at gmail.com> wrote:
> I have the ubuntu gdal package installed in /usr plus a compiled
> version in /usr/local which I need to support some extra formats. As
> far as I can tell, both versions of gdal are functioning 100%
Matt,
This is almost certainly the cause of your problem. The error
is basically indicating that MapServer was compiled using include
files with one definition of the Set methods, but you linked against
a shared library with a different definition. These methods had
a "const correctness" change that is normally invisible to
applications, but does change the ABI (the mangled internal
names of methods).
My suggestion is that you uninstall the package from
/usr, if you are installing your own custom build in /usr/local.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
