Mapserver compile error on Ubuntu
Pericles S. Nacionales
naci0002 at UMN.EDU
Mon Jan 16 12:36:47 EST 2006
Greetings, Till!
I was just about to pull out my laptop with Ubuntu... haven't used it
in quite sometime. I've compiled MapServer, GRASS, and GDAL/OGR in
Ubuntu before without any problems so I'm curious to see what Matt's
problem is all about. It could be that he's missing some header files...
Matt, did you download the "dev" packages for GDAL and other dependencies?
-Perry
Till Adams wrote:
> Dear Perry,
> we love Ubuntu because we never got less errors while compiling UMN
> (none).
> We take all the libs from breezy (also libgdal and libgdal-dev) and
> compile like this:
> # ./configure --with-gd -- with-gdal=/usr/bin/gdal-config --with-ogr
> --with-wms...
> and all the rest we want without giving any pathes. If you make
> # find -name gdal-config
> it is located in "/usr/bin/"
> Everything Works. Did you take any of the libs (gdal, gd, freetype,
> ..) from sources and not as
> package?
> Till
> Matthew Perry schrieb:
>> Perry,
>> On 1/15/06, Pericles S. Nacionales <naci0002 at umn.edu> wrote:
>>> What happens if you run configure with this:
>>> ./configure --with-wmsclient --with-wfsclient
>>> --with-gdal=/usr/local/bin/gdal-config --with-ogr --with-proj
>>> (Don't pass the path to "--with-ogr" parameter).
>> Same error. I tried without specifying any paths and tried specifying
>> the the official ubuntu gdal binaries in /usr/bin with the same
>> results.
>> matt
>>> Matthew Perry wrote:
>>>> Hey folks,
>>>> I'm installing mapserver 4.6.2 from source on ubuntu breezy and I'm
>>>> running into some errors. I built most dependencies with "apt-get
>>>> build-dep mapserver-bin", built my own gdal cvs (from 01/11/06) in
>>>> /usr/local and configured with:
>>>> --with-gdal=/usr/local/bin/gdal-config --with-proj
>>>> --with-ogr=/usr/local/bin/gdal-config
>>>> But make is giving me the following errors:
>>>> gcc -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT
>>>> -DUSE_EPPL -DUSE_PROJ -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_LYR
>>>> -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
>>>> -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_OGR -DUSE_GDAL
>>>> -DUSE_ICONV -DUSE_ZLIB -I/usr/include -I/usr/local/include
>>>> shp2img.o -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype
>>>> -lpng -lz -lXpm -lX11 -ljpeg -lfreetype -lpng -lz -lXpm -lX11
>>>> -lproj -ljpeg -L/usr/local/lib -lgdal -L/usr/lib -lcurl -lidn
>>>> -lssl -lcrypto -ldl -lssl -lcrypto -ldl -lz -lc -lz -lm -lstdc++
>>>> -o shp2img
>>>> ./libmap.a(mapogr.o): In function `msOGRFileWhichShapes(layer_obj*,
>>>> rectObj, ms_ogr_file_info_t*)':
>>>> mapogr.cpp:(.text+0x516): undefined reference to
>>>> `OGRLineString::setPoint(int, double, double)'
>>>> mapogr.cpp:(.text+0x52e): undefined reference to
>>>> mapogr.cpp:(.text+0x54c): undefined reference to
>>>> mapogr.cpp:(.text+0x56a): undefined reference to
>>>> mapogr.cpp:(.text+0x582): undefined reference to
>>>> collect2: ld returned 1 exit status
>>>> make: *** [shp2img] Error 1
>>>> I've tried this on two other installations of Ubuntu and get the exact
>>>> same error even when compiling against older versions of gdal which I
>>>> know to be stable. If i compile without gdal/ogr it works fine. Does
>>>> anyone have any hints about where I can begin debugging this?
>>>> Matt Perry
>>>> perrygeo at gmail.com
>>>> http://www.perrygeo.net
>> Matt Perry
