negative values and colors in Ascii Grids
    Carola Jesch
    cjesch at CCT.LSU.EDU
    Mon Jan 16 11:46:54 PST 2006
Hi Frank,
I had a look to the raster-howto and the sources as well, but was unsure,
because I can't imagine that most users have grids that exactly have values
between 0 and 255 in it.
So sorry fot the questions.
Do you plan to implement a colormap for ascii grids like the clr for binary
grids? What would you suggest to display the negative values?
Thanks, Carola
> -----Original Message-----
> From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On
> Behalf Of Frank Warmerdam
> Sent: Monday, January 16, 2006 7:29 AM
> To: Carola Jesch
> Cc: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] negative values and colors
> in Ascii Grids
> On 1/15/06, Carola Jesch <cjesch at cct.lsu.edu> wrote:
> > Hi,
> > I have an contineous ASCII GRID (floating values) that I
> would like to
> > display in MapServer. This grid shows bathymetry (ocean)
> and elevation
> > (land) data. There are a lot of negative values for the ocean,
> > starting from -1500 to 0 and only a small range for the land (0 to
> > 20). When I am trying to display the grid, the entire image
> is black.
> > Does MapServer support negative values? How can I display
> the grid with colors?
> > I have tried to convert the Ascii file to a binary grid,
> but I don't
> > know how to create a colormap (*.clr). ArcGIS doesn't seem
> to support
> > this or does anyone of you how to do that?
> Carola,
> By default Mapserver will read the grid values directly, and
> clip any values outside the range 0 to 255 the bounds.  So
> all your negative values are cliipped to zero, and the top
> value is 20  (out of 255) which would appear nearly black.
> The first step I would suggest is enabling autoscaling with
> the layer directive:
>   PROCESSING "SCALE=AUTO"
> Beyond that I would suggest you review the raster howto.
>   http://mapserver.gis.umn.edu/docs/howto/raster_data
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
More information about the MapServer-users
