negative values and colors in Ascii Grids
Frank Warmerdam
warmerdam at POBOX.COM
Mon Jan 16 15:03:02 EST 2006
On 1/16/06, Carola Jesch <cjesch at cct.lsu.edu> wrote:
> Hi Frank,
> I had a look to the raster-howto and the sources as well, but was unsure,
> because I can't imagine that most users have grids that exactly have values
> between 0 and 255 in it.
Carola,
Well, most folks are working with simple 8bit images where
scaling is not required.
> So sorry fot the questions.
> Do you plan to implement a colormap for ascii grids like the clr for binary
> grids?
I wasn't planning to do so, but it looks like it wouldn't be too hard.
Note that ASCII grids are a terrible format to run mapserver from
due to the amount of processing required when reading it.
> What would you suggest to display the negative values?
If you want detailed control of the colors then create a series of
classes. If a greyscale is fine then just use automatic or
explicit scaling values.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
