negative values and colors in Ascii Grids
Christopher Condit
condit at SDSC.EDU
Mon Jan 16 16:12:28 EST 2006
Hi Frank-
I'm also very interested in this topic and have been trying to
efficiently create raster images from continuous oracle point sources.
Currently, I write the Oracle points to a ArcInfo ASCII grid and create
all of my own CLASS directives for MapServer. Do you know of a better
way to do this? Problem is: I need the raster to come from a DB query
input by the user, so I can't create static images ahead of time...
Thanks!
Chris
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Frank Warmerdam
Sent: Monday, January 16, 2006 12:03 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] negative values and colors in Ascii
Grids
On 1/16/06, Carola Jesch <cjesch at cct.lsu.edu> wrote:
> Hi Frank,
> I had a look to the raster-howto and the sources as well, but was
unsure,
> because I can't imagine that most users have grids that exactly have
values
> between 0 and 255 in it.
Carola,
Well, most folks are working with simple 8bit images where
scaling is not required.
> So sorry fot the questions.
> Do you plan to implement a colormap for ascii grids like the clr for
binary
> grids?
I wasn't planning to do so, but it looks like it wouldn't be too hard.
Note that ASCII grids are a terrible format to run mapserver from
due to the amount of processing required when reading it.
> What would you suggest to display the negative values?
If you want detailed control of the colors then create a series of
classes. If a greyscale is fine then just use automatic or
explicit scaling values.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
