Mapserver compile error on Ubuntu
Pericles S. Nacionales
naci0002 at UMN.EDU
Mon Jan 16 12:38:10 PST 2006
Frank Warmerdam wrote:
>On 1/16/06, Matthew Perry <perrygeo at gmail.com> wrote:
>>I have the ubuntu gdal package installed in /usr plus a compiled
>>version in /usr/local which I need to support some extra formats. As
>>far as I can tell, both versions of gdal are functioning 100%
>Matt,
>This is almost certainly the cause of your problem. The error
>is basically indicating that MapServer was compiled using include
>files with one definition of the Set methods, but you linked against
>a shared library with a different definition. These methods had
>a "const correctness" change that is normally invisible to
>applications, but does change the ABI (the mangled internal
>names of methods).
>My suggestion is that you uninstall the package from
>/usr, if you are installing your own custom build in /usr/local.
Oops, didn't catch that one. What Frank said! ;)
-Perry
More information about the MapServer-users
