Serving MrSidd images
Serkan Girgin
girgink at GMAIL.COM
Tue Jan 17 16:49:14 EST 2006
Hi!
If you want you can re-compress GeoTIFF into ECW (directly supported by
MapServer) using gdal_translate to save space. Even without break down to
smaller tiles the performance is also very good, at least for my case (1.5Gb
single file, 135093x67205 pixels).
Regards,
Serkan Girgin
girgink at gmail.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Neil "Nemo" Martinko
Sent: Tuesday, January 17, 2006 10:18 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Serving MrSidd images
You can download the LizardTech MrSID Decode program and make your MrSID
files into GeoTIFFs.
Yes, you can... But remember, MrSIDs are COMPRESSED.
I have a MrSID of my county that is almost 1GB. I wanted to serve it with
MapServer, so I came up with "the plan"... 1) Break the MrSID into sixteen
GeoTIFFs with mrsiddecode. 2) Create an index with gdaltindex. 3) Add the
index to a mapfile.
I created a small Python script to complete step 1... And wound up with
sixteen GeoTIFFs that totaled nearly 15GB.
Nemo -- Iron County Forestry and Parks Dept
