php5 Linux
O. El Gawhary
ing.elgawhary at TISCALI.IT
Wed Jan 18 05:27:09 EST 2006
>-- Messaggio Originale --
>Date: Tue, 17 Jan 2006 11:12:01 -0600
>Reply-To: Adam J Siber <siberjunk at COMCAST.NET>
>From: Adam J Siber <siberjunk at COMCAST.NET>
>Subject: [UMN_MAPSERVER-USERS] php5 Linux
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>I am trying to configure mapserver with php5 on linux as a DSO but not
>having much success? I have searched the boards/lists for instructions,
>hints, etc but have only seen a couple listings which are limited. Could
>someone please post a "how to" or some notes on this subject.
>Thank you,
>Adam
Adam,
You can install Apache2 with --enable-modules=so option:
$ ./configure --enable-modules=so
$ make
$ make install
and PHP (as module) in this way:
$ ./configure --with-apxs2=/path/to/apxs/executable
$ make
$ make install
The procedure generates a loadable module (libphp5.so).It is necessary to
change the Apache configuration file httpd.conf as the following:
LoadModule php5_module /path/to/module/ (if not present)
Addtype application/x-httpd-php .php .phtml
(obviously if you want that PHP manage .php and .phtml files)
to allow Apache load the module.
After that you can install Mapserver. But, if I'm not in error, Mascript
is supported as CGI and not as DSO, so with the previous installation you
can have some problems.
Regards.
Omar
_________________________________________________________________
TISCALI ADSL Web&Mail
Solo con Tiscali Adsl navighi e telefoni senza canone Telecom a partire da
14,95 Euro/mese. Attivala subito!
Per te 500 MB inclusi per navigare, inviare e ricevere messaggi e-mail, foto
ed mp3.
http://abbonati.tiscali.it/adsl/sa/2wam_tc/
