Mapserver compile error on Ubuntu (solved... sort of)
Matthew Perry
perrygeo at GMAIL.COM
Tue Jan 17 10:46:38 PST 2006
Thanks everybody for the help. The problem was the two conflicting
versions of gdal in /usr and /usr/local . By removing the ubuntu
"libgdal1c2" package, I was able to compile mapserver fine. Of course
removing the packaged ubunut gdal libs means you can't use the qgis,
thuban or grass packages so these must be compiled against the local
gdal as well.
sudo apt-get build-dep mapserver
sudo apt-get install flex bison
./configure --with-tiff --with-jpeg --with-png --with-freetype
--with-zlib --with-threads --with-proj
--with-gdal=/usr/local/bin/gdal-config --with-wcs --with-ogr
--with-wmsclient --with-wfsclient --without-pdf --with-geos
--enable-debug
make
sudo make install
Thanks again,
On 1/16/06, Matthew Perry <perrygeo at gmail.com> wrote:
> Frank,
> On 1/16/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > Of course it is possible to differentiate, but it can be
> > pretty tricky. And I don't know the details of how
> > things get installed on Ubuntu, or how you built things
> > for the /usr/local install.
> > What does "ldd /usr/bin/gdalinfo" report?
> Ahhh. This might be a problem..
> libgdal.so.1 => /usr/local/lib/libgdal.so.1 (0xb7beb000)
> So the /usr version is looking to the /usr/local libs. I'm doing all
> the library paths through ld.so.conf. You're right... this will get
> tricky!
> I'm thinking that removing the /usr version of gdal is probably the
> best bet since ideally I'd like all my apps running off the /usr/local
> version anyways. I'll go this route for now.
> Matt Perry
> http://www.perrygeo.net
More information about the MapServer-users
