Problem in Oracle Spatial with MapServer in ItemnQuery
Prema Selvam (sent by Nabble.com)
lists at NABBLE.COM
Wed Jan 18 10:56:05 EST 2006
Hi All,
Thanks all for the solution of my previous query ( Problem in Oracle Spatial Connection - Empty Image).
Now I got new query, Please give me some solution.
I am able to establish connection between MapServer and Oracle Spatial 10g, and we can get the Map Image prefectly ( refer Subject Problem in Oracle Spatial Connection - Empty Image )
I am unable to get the any Query Function in MapServer with Oracle Spatial , but i can able to do the query operation with Shapefiles.
The Mapfile, quey and Error is give below,
Mapfile
MAP
DEBUG ON
NAME World_Country
EXTENT -180 -90 180 83.60415649414
SIZE 800 400
SHAPEPATH '/ms4w/apps/zap/data/'
IMAGETYPE GIF
STATUS ON
WEB
TEMPLATE 'templates/ZapTemp.html'
IMAGEPATH '/ms4w/tmp/ms_tmp/'
IMAGEURL '/ms_tmp/'
END
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
QUERYMAP
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
LAYER
DEBUG ON
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
CONNECTIONTYPE oraclespatial
CONNECTION "world/land at orcl"
DATA "shape FROM world USING SRID 8307"
NAME world_poly
STATUS ON
TYPE POLYGON
DUMP TRUE
TEMPLATE "templates/ZapTemp.html"
TOLERANCE 5
CLASS
NAME 'The_World'
STYLE
COLOR 0 200 0
END
END
END
END
Query
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/zap/htdocs/CountryOrcl.map&mode=itemnquery&layer=world_poly&qlayer=world_poly&qitem=cntry_name&qstring=india
Error Message
msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error: ORA-00920: invalid relational operator . Query statement: SELECT rownum, cntry_name, shape FROM world WHERE india AND SDO_FILTER( shape, MDSYS.SDO_GEOMETRY(2003, 8307, NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-180,-90,180,83.6041565) ),'querytype=window') = 'TRUE' . Check your data statement.
Spatial data in Oracle
SQL> describe world
Name Null? Type
SHAPEID NOT NULL NUMBER(38)
FIPS_CNTRY VARCHAR2(2)
GMI_CNTRY VARCHAR2(3)
ISO_2DIGIT VARCHAR2(2)
ISO_3DIGIT VARCHAR2(3)
CNTRY_NAME VARCHAR2(254)
LONG_NAME VARCHAR2(40)
SOVEREIGN VARCHAR2(40)
POP_CNTRY NUMBER
CURR_TYPE VARCHAR2(16)
CURR_CODE VARCHAR2(4)
LANDLOCKED VARCHAR2(1)
SQKM NUMBER
SQMI NUMBER
COLORMAP NUMBER
SHAPE MDSYS.SDO_GEOMETRY
Please give me a some solution
Waiting for the reply
Thanks & Regards,
Prema Selvam
GISbiz
View this message in context: http://www.nabble.com/Problem-in-Oracle-Spatial-with-MapServer-in-ItemnQuery-t945593.html#a2449588
Sent from the Mapserver - User forum at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060118/2af71653/attachment.html
