Using C#: Unable to load DLL 'mapscript': The specified module
could not be found.
Eduard Witteveen
e.witteveen at HAWARIT.COM
Thu Jan 19 05:49:59 EST 2006
Hello list,
While i tried to create an application which uses mapserver
(http://hobu.stat.iastate.edu/mapserver/mapserver/build_output/4_6/full.zip)
i get the error that it cannot load the DLL 'mapscript'.
I following steps were taken by me:
- Download
- Create a Console application in MS VS 2005 C#
- Add the csharp/examples/drawmap.cs to the project
- Add the csharp/mapscript_csharp.dll as reference to the project
The project builds succesfull
When i try to run the executable i get the following error:
> System.TypeInitializationException: The type initializer for 'mapscriptPINVOKE' threw an exception. ---> System.TypeInitializationException: The type initializer for 'SWIGExceptionHelper' threw an exception. ---> System.DllNotFoundException: Unable to load DLL 'mapscript': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
> at mapscriptPINVOKE.SWIGExceptionHelper.SWIGRegisterExceptionCallbacks_mapscript(ExceptionDelegate applicationDelegate, ExceptionDelegate arithmeticDelegate, ExceptionDelegate divideByZeroDelegate, ExceptionDelegate indexOutOfRangeDelegate, ExceptionDelegate invalidOperationDelegate, ExceptionDelegate ioDelegate, ExceptionDelegate nullReferenceDelegate, ExceptionDelegate outOfMemoryDelegate, ExceptionDelegate overflowDelegate, ExceptionDelegate systemExceptionDelegate)
> at mapscriptPINVOKE.SWIGExceptionHelper..cctor()
> --- End of inner exception stack trace ---
> at mapscriptPINVOKE.SWIGExceptionHelper..ctor()
> at mapscriptPINVOKE..cctor()
> at mapscriptPINVOKE.new_mapObj(String jarg1)
> at mapObj..ctor(String filename)
Which clearly contains the message:
I tried placing the csharpt/mapscript.dll in the \bin\Debug\ folder and
i placed it inside the c:\windows\system32\ folder, but i still receive
the error.
I've tried to find more information about this message, but my best
friend couldnt find anything about it.
How can i make this application run succesfully / where do i have to
place the mapscript.dll(or more files?) ?
mvg,
Ing. Eduard Yeb Witteveen Software Engineer
Hawar Information Technology bv lid Dijkoraad Groep
De Wymerts 7 8701 WT Bolsward
Tel: +31 (0)515 570333 Fax: +31 (0)515 570335
http://www.hawarit.com/ nl_NL fy_NL en_US
