Problem in MapServer with Oracle Spatial - More than one image is
Loaded
Prema Selvam (sent by Nabble.com)
lists at NABBLE.COM
Thu Jan 19 11:13:03 EST 2006
Hi Everybody,
Again its Me,
I can able to Connect to Oracle Spatial with MapServer and i can fire the Itemnquery function.
But the problem , when i fire the ItemQuery only one record is hilited thats the default it return only first match record.
When I fire Itemnquery more than one image is generated that is if 50 records is matched 50 same image is loaded .
Please give me a some solution for this problem, below I am give the Mapfile, Template, Query and Output.
Mapfile
MAP
DEBUG ON
NAME world_city
EXTENT -180 -90 180 83.60415649414
SIZE 800 400
SHAPEPATH '/ms4w/apps/zap/data/'
IMAGETYPE GIF
STATUS ON
SYMBOL
NAME "circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
WEB
TEMPLATE 'templates/ZapTemp.html'
IMAGEPATH '/ms4w/tmp/ms_tmp/'
IMAGEURL '/ms_tmp/'
END
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
QUERYMAP
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
LAYER
DEBUG ON
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
CONNECTIONTYPE oraclespatial
CONNECTION "world/land at orcl"
DATA "shape FROM world USING UNIQUE shapeid SRID 8307"
NAME world_point
STATUS ON
TYPE POINT
DUMP TRUE
TEMPLATE "templates/ZapTemp.html"
TOLERANCE 5
CLASS
NAME 'World_Class'
SYMBOL "circle"
SIZE 7
COLOR 128 64 64
OUTLINECOLOR 0 0 0
END
END # World polygon layer ends here
END
Template
Query
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/zap/htdocs/world1.map&mode=itemnquery&layer=world_point&qlayer=world_point&qitem=ploc&qstring=ploc='pondicherry'
ploc is the Filed name
Output file
Thanks & Regards
Prema Selvam
GISbiz
View this message in context: http://www.nabble.com/Problem-in-MapServer-with-Oracle-Spatial---More-than-one-image-is-Loaded-t954228.html#a2472128
Sent from the Mapserver - User forum at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060119/e236063c/attachment.html
