Problem in MapServer with Oracle Spatial - More than one
image is Loaded
Fawcett, David
David.Fawcett at PCA.STATE.MN.US
Thu Jan 19 11:18:01 EST 2006
Prema,
A quick solution is to put your image tag in the header or footer
template and take it out of the main template. The header and footer
get processed only once per query. The main query template gets
processed once for each record.
David.
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Prema Selvam (sent
by Nabble.com)
Sent: Thursday, January 19, 2006 10:13 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Problem in MapServer with Oracle
Spatial - More than one image is Loaded
Hi Everybody,
Again its Me,
I can able to Connect to Oracle Spatial with MapServer and i
can fire the Itemnquery function.
But the problem , when i fire the ItemQuery only one record is
hilited thats the default it return only first match record.
When I fire Itemnquery more than one image is generated that
is if 50 records is matched 50 same image is loaded.
Please give me a some solution for this problem, below I am
give the Mapfile, Template, Query and Output.
Mapfile
MAP
DEBUG ON
NAME world_city
EXTENT -180 -90 180 83.60415649414
SIZE 800 400
SHAPEPATH '/ms4w/apps/zap/data/'
IMAGETYPE GIF
STATUS ON
SYMBOL
NAME "circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
WEB
TEMPLATE 'templates/ZapTemp.html'
IMAGEPATH '/ms4w/tmp/ms_tmp/'
IMAGEURL '/ms_tmp/'
END
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
QUERYMAP
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
LAYER
DEBUG ON
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
CONNECTIONTYPE oraclespatial
CONNECTION "world/land at orcl"
DATA "shape FROM world USING UNIQUE
shapeid SRID 8307"
NAME world_point
STATUS ON
TYPE POINT
DUMP TRUE
TEMPLATE "templates/ZapTemp.html"
TOLERANCE 5
CLASS
NAME 'World_Class'
SYMBOL "circle"
SIZE 7
COLOR 128 64 64
OUTLINECOLOR 0 0 0
END
END # World polygon layer ends here
END
Template
<HTML>
<body>
</body>
</HTML>
Query
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/zap/htdocs/world1.ma
p&mode=itemnquery&layer=world_point&qlayer=world_point&qitem=ploc&qstrin
g=ploc='pondicherry'
ploc is the Filed name
Output file
<HTML>
<body>
</body>
</HTML>
<HTML>
<body>
</body>
</HTML>
<HTML>
<body>
</body>
</HTML>
<HTML>
<body>
</body>
</HTML>
<HTML>
<body>
</body>
</HTML>
<HTML>
<body>
Thanks & Regards
Prema Selvam
GISbiz
View this message in context: Problem in MapServer with Oracle
<http://www.nabble.com/Problem-in-MapServer-with-Oracle-Spatial---More-t
han-one-image-is-Loaded-t954228.html#a2472128>
Sent from the Mapserver - User
<http://www.nabble.com/Mapserver---User-f1215.html> forum at
Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060119/f19cd292/attachment.html
