Problem in MapServer with Oracle Spatial - More than one image is Loaded
Prema Selvam (sent by Nabble.com)
lists at NABBLE.COM
Thu Jan 19 22:28:51 PST 2006
Hi David,
Thanks for the quick reply,
Know I can get Single Map image but the in the HTML Source the main template is repeated for same number of times (as 50 records the template is processed for 50 times), because i put the result information in the template file.
I included the Footer and Header in the Map File.
Here I given the Template, Footer, Header files nad template file.
Header
MapServer - Oracle Spatial
I pass the same query
Query
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/zap/htdocs/world1.map&mode=itemnquery&layer=world_point&qlayer=world_point&qitem=ploc&qstring=ploc='pondicherry'
Output Source
html>
Please Send me some solution
I am waiting for the reply
Regards,
Prema Selvam
GISbiz
View this message in context: http://www.nabble.com/Problem-in-MapServer-with-Oracle-Spatial---More-than-one-image-is-Loaded-t954228.html#a2485254
Sent from the Mapserver - User forum at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060119/56bd5c2a/attachment.htm>
More information about the MapServer-users
