Using C#: Unable to load DLL 'mapscript': The specified
module could not be found.
Eduard Witteveen
e.witteveen at HAWARIT.COM
Fri Jan 20 09:09:32 EST 2006
Tamas Szekeres wrote:
> I recommend that all of the dll-s belonging to your app. to be placed into
> your application's directory ie bin/Debug due to avoid further problems. It
> is not alien from the philosophy of the .NET stuff.
Which version is the best version to use for .NET development?
http://hobu.stat.iastate.edu/mapserver/mapserver/build_output/4_6/full.zip
didn't work for me, however
http://hobu.stat.iastate.edu/mapserver/mapserver/build_output/4_6/debug.zip
worked without any problems.
(is there also a release build of this version?)
Thanks for all the quick responses! I can now continue development!
Ing. Eduard Yeb Witteveen Software Engineer
Hawar Information Technology bv lid Dijkoraad Groep
De Wymerts 7 8701 WT Bolsward
Tel: +31 (0)515 570333 Fax: +31 (0)515 570335
http://www.hawarit.com/ nl_NL fy_NL en_US
