raster maps and mapserver
Matthew Perry
perrygeo at GMAIL.COM
Fri Jan 20 13:19:20 EST 2006
Yes it is possible to set up direct grass raster support in mapserver.
Grass support is obtained through GDAL so if gdal supports grass, then
mapserver will too. You might be able to find an rpm for the
gdal-grass plugin.
If you type "gdalinfo --formats" and you see GRASS, you'll know its
working. You can access the rasters in mapserver by setting your DATA
parameter to "/location/mapset/cellhd/rastername"
matt
On 1/20/06, Alexia81 <alexia81 at email.it> wrote:
> Hi!
> How can i view raster map with mapserver directly from grass location
> without creating GEOTIF images?
> My rasters are contains float data.
> Configuration:
> - Fedora core 3
> - grass60 and 61 installed from binary package
> - mapserver-4.6 installed from binary package
> N.B. mapserver examples are running, but ./mapserv -v did not produce any
> output
> Email.it, the professional e-mail, gratis per te: http://www.email.it/f
> Sponsor:
> Per i progetti che rimandi da tempo, Findomestic ti offre la soluzione
> ideale per te, con semplicità e senza anticipi! Clicca e scopri come
> Clicca qui: http://adv.email.it/cgi-bin/foclick.cgi?mid=3936&d=20060120
Matt Perry
perrygeo at gmail.com
http://www.perrygeo.net
