Kernel Density Mapping?
Bill Binko
bill at BINKO.NET
Fri Jan 20 16:57:16 EST 2006
Brent,
Thanks for the info. I will certainly look at the R tools: I was
unaware of an S replacement (it's been years since I've seen S).
It does seem (from what little research I've done) that these R tools
will generate images, and not shapefiles.
I am primarily like to take Point datasets, and generate polygon
datasets. I suppose I could take R, generate rasters, and then use
gdal_contour to generate the vectors?
However, I am willing (and probably capable) of writing a tool that can
process the points, run the kernel function and generate the resulting
contours directly. Does anyone know where I can find a good description
of the algorithm and/or some sample code for it? Perhaps one of the
professors out there?
Of course, if I did so, I'd be happy to push it back to the community.
Bill
Brent Wood wrote:
>--- Bill Binko <bill at BINKO.NET> wrote:
>>Hi everyone,
>>[I've been sidelined recently battling some painful bugs in GDAL,
>>Mapserver, and several raster libs, so I've been putting off some more
>>general questions I'd love to pose to the list. This is my first, but
>>I'll probably send several tonight (sorry to flood).]
>>I'm interested in creating "kernel method" density maps using vector
>>point data.
>Look at R for this sort of thing, I know several fisheries modellers using R
>for kernel density analyses. R/PostGIS/GRASS/QGIS/mapserver (with Proj.4, GDAL,
>GEOS, etc...) all work pretty well together to support such work as an Open
>Source suite.
>See:
>http://www.stat.math.ethz.ch/R-manual/R-devel/library/stats/html/density.html
>For a more general list of R functions,
>http://www.oulu.fi/atkk/tkpalv/unix/R/library/stats/html/00Index.html
>and for general R spatial packages/info,
>http://r-spatial.sourceforge.net/
>Hope this helps....
> Brent Wood
