Horrible Looking WMS Raster Imagery
Brent Pedersen bpederse at NATURE.BERKELEY.EDU
Mon Jan 23 20:48:00 PST 2006
have you tried using image/jpeg?
On Jan 23, 2006, at 8:39 PM, Jennifer Zeisloft wrote:
> Thank you for responding, Ed.
> Actually, these raster data sets are displayed as part of Chameleon
> contexts (so there is no mapfile).  I added the USGS orthos to a
> mapfile to see if the result was any different and it wasn't (the
> mapfile code for this layer is pasted below in any case).
> The application can be found at http://maps.aqua.wisc.edu/lscmp/
> viewmaps.phtml.  The example data sets I am referring to can be
> found in the Wisconsin: Imagery context.
> I have read through the documentation on rasters in MapServer, as
> well as searched list archives and have not been able to determine
> how I would go about specifying low or high -color output.  So,
> perhaps this is part of the problem?
> Again, any suggestions are greatly appreciated!!
> Jennifer Zeisloft
> LAYER
>   NAME DOQ
>   STATUS ON
>   CONNECTIONTYPE WMS
>   TYPE RASTER
>   CONNECTION "http://terraservice.net/ogcmap.ashx"
>   PROJECTION
>    "init=epsg:4326"
>   END # Projection
>   METADATA
>    "wms_srs"             "EPSG:4326"
>    "wms_name"            "DOQ"
>    "wms_title"           "USGS Digital Ortho-Quadrangles"
>    "wms_onlineresource"  "http://terraservice.net/ogcmap.ashx"
>    "wms_abstract"        "NA - test"
>    "wms_keywordlist"     "NA -test"
>    "wms_server_version"  "1.1.1"
>    "wms_formatlist"      "image/png,image/jpeg,image/wbmp"
>    "wms_format"          "image/png"
>   END # Metadata
> END # layer
> On 1/23/06, Ed McNierney <ed at topozone.com> wrote:
> Jennifer -
> You don't give us much information to go on, other than your
> dislike of the results!
> If you're consistently seeing poor-quality results, then there may
> well be something systematic you're doing in your map files or
> MapServer configuration.  I'm assuming you're using MapServer to
> generate these "horrible-looking" images.  If you are, for example,
> requesting low-color output from high-color images, you're going to
> see blotchy output.  DRGs are low-color images (only 13 unique
> colors) so they are not as prone to being affected by a low-color
> output request.
> Could you provide an example of the map file and configuration
> you're using to retrieve and display these images?  There's nothing
> special about the WMS interface that inherently limits image
> quality - you can get a perfect reproduction of the source imagery
> in many cases.
>     - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA  01863
> Phone: +1 (978) 251-4242
> Fax: +1 (978) 251-1396
> ed at topozone.com
> From: UMN MapServer Users List [mailto:MAPSERVER-
> USERS at LISTS.UMN.EDU] On Behalf Of Jennifer Zeisloft
> Sent: Monday, January 23, 2006 10:00 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Horrible Looking WMS Raster Imagery
> Greetings All,
> We have been noticing that some (but not all) WMS raster images
> look pretty terrible (extremely low resolution compared to what
> they should be) when added to our MapServer application.  For
> instance, from TerraServer (http://terraservice.net/ogcmap.ashx),
> USGS Digital Ortho Quads are virtually useless regardless of scale,
> while USGS DRGs look decent.  Daily MODIS imagery from NASA JPL
> World Map Service (http://wms.jpl.nasa.gov/wms.cgi?) has also
> typically been a problem.  And there are others...
> I have recently been playing with GDAL to display our own rasters,
> but also partially with the hope that it might somehow magically
> fix this problem (of course it hasn't).
> I am wondering whether the display problem is local or if it is on
> the data custodian's end, and whether this is typically the case.
> Is there any way to correct it?  If it is at the custodial end,
> what might be done differently to increase the display resolution
> for WMS clients (so that we don't make the same mistake)?
> I really appreciate any hints or ideas you can offer.
> Thanks much!
> Jennifer Zeisloft
> UW Sea Grant
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060123/fd2b6f70/attachment.htm>
More information about the MapServer-users mailing list
