Horrible Looking WMS Raster Imagery
Jennifer Zeisloft
jzeisloft at GMAIL.COM
Mon Jan 23 23:59:53 EST 2006
Brent,
Thanks for the suggestion. I switched the output from png to jpeg - but no
change (the jpeg might have looked a little worse??). Still, the crux of
the matter is, I suppose, that these images are displayed through a context
file. The rasters are coming straight from their "original" (perhaps)
source, which doesn't allow me to specify how the image is displayed, but
merely that an image is displayed (furthermore, the context file is
automatically generated by the "Save Context" widget in Chameleon).
And an addendum to my last message: I did find output specifications in the
documentation (
http://mapserver.gis.umn.edu/docs/reference/mapfile/outputformat/), but I
don't have the opportunity in this instance to specify the output in this
sense.
Jennifer
On 1/23/06, Brent Pedersen <bpederse at nature.berkeley.edu> wrote:
> have you tried using image/jpeg?
> On Jan 23, 2006, at 8:39 PM, Jennifer Zeisloft wrote:
> Thank you for responding, Ed.
> Actually, these raster data sets are displayed as part of Chameleon
> contexts (so there is no mapfile). I added the USGS orthos to a mapfile to
> see if the result was any different and it wasn't (the mapfile code for this
> layer is pasted below in any case).
> The application can be found at
> http://maps.aqua.wisc.edu/lscmp/viewmaps.phtml. The example data sets I
> am referring to can be found in the Wisconsin: Imagery context.
> I have read through the documentation on rasters in MapServer, as well as
> searched list archives and have not been able to determine how I would go
> about specifying low or high -color output. So, perhaps this is part of the
> problem?
> Again, any suggestions are greatly appreciated!!
> Jennifer Zeisloft
> LAYER
> NAME DOQ
> STATUS ON
> CONNECTIONTYPE WMS
> TYPE RASTER
> CONNECTION "http://terraservice.net/ogcmap.ashx"
> PROJECTION
> "init=epsg:4326"
> END # Projection
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "DOQ"
> "wms_title" "USGS Digital Ortho-Quadrangles"
> "wms_onlineresource" "http://terraservice.net/ogcmap.ashx"
> "wms_abstract" "NA - test"
> "wms_keywordlist" "NA -test"
> "wms_server_version" "1.1.1"
> "wms_formatlist" "image/png,image/jpeg,image/wbmp"
> "wms_format" "image/png"
> END # Metadata
> END # layer
> On 1/23/06, Ed McNierney <ed at topozone.com> wrote:
> > Jennifer -
> > You don't give us much information to go on, other than your dislike of
> > the results!
> > If you're consistently seeing poor-quality results, then there may well
> > be something systematic you're doing in your map files or MapServer
> > configuration. I'm assuming you're using MapServer to generate these
> > "horrible-looking" images. If you are, for example, requesting low-color
> > output from high-color images, you're going to see blotchy output. DRGs are
> > low-color images (only 13 unique colors) so they are not as prone to being
> > affected by a low-color output request.
> > Could you provide an example of the map file and configuration you're
> > using to retrieve and display these images? There's nothing special about
> > the WMS interface that inherently limits image quality - you can get a
> > perfect reproduction of the source imagery in many cases.
> > - Ed
> > Ed McNierney
> > President and Chief Mapmaker
> > TopoZone.com / Maps a la carte, Inc.
> > 73 Princeton Street, Suite 305
> > North Chelmsford, MA 01863
> > Phone: +1 (978) 251-4242
> > Fax: +1 (978) 251-1396
> > ed at topozone.com
> > *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> > *On Behalf Of *Jennifer Zeisloft
> > *Sent:* Monday, January 23, 2006 10:00 PM
> > *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> > *Subject:* [UMN_MAPSERVER-USERS] Horrible Looking WMS Raster Imagery
> > Greetings All,
> > We have been noticing that some (but not all) WMS raster images look
> > pretty terrible (extremely low resolution compared to what they should be)
> > when added to our MapServer application. For instance, from TerraServer (
> > http://terraservice.net/ogcmap.ashx), USGS Digital Ortho Quads are
> > virtually useless regardless of scale, while USGS DRGs look decent. Daily
> > MODIS imagery from NASA JPL World Map Service (
> > http://wms.jpl.nasa.gov/wms.cgi?) has also typically been a problem.
> > And there are others...
> > I have recently been playing with GDAL to display our own rasters, but
> > also partially with the hope that it might somehow magically fix this
> > problem (of course it hasn't).
> > I am wondering whether the display problem is local or if it is on the
> > data custodian's end, and whether this is typically the case. Is there any
> > way to correct it? If it is at the custodial end, what might be done
> > differently to increase the display resolution for WMS clients (so that we
> > don't make the same mistake)?
> > I really appreciate any hints or ideas you can offer.
> > Thanks much!
> > Jennifer Zeisloft
> > UW Sea Grant
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060123/bb333021/attachment.html
